Tapping noise when started up and when accelerating?
2004 FORD EXPEDITION
250,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
CTISH84
  • 4 POSTS
My vehicle listed above makes a tapping noise when started up and when accelerating, what causes this and is it something that can be fixed?
Thanks, Crissy
Mar 25, 2025 at 4:07 PM
Hello Crissy,
It sounds like you have an exhaust leak or a loose spark plug. Can you please upload a short video from your phone of the noise from under the hood so I can tell for sure?
Here is a guide for engine noises you can go over in the meantime:
https://www.2carpros.com/articles/engine-noises
Mar 27, 2025 at 9:44 AM
CTISH84
  • 4 POSTS
I hope this helps, thanks again.
Mar 27, 2025 at 2:26 PM
CTISH84
  • 4 POSTS
I wanted to let the Mechanic know I just found out from the lady I bought my vehicle from that the oil hasn't been changed in 2 years. I know that's not good could that be what's causing the tapping noise?
Mar 28, 2025 at 7:31 AM
Yes, I would change the oil and have a new filter, if this does not help it sounds like you have a roller follower or timing chain, that is the problem.
Please go over this video:
https://youtu.be/SI8UaVvjvEM?si=JhiMNcGGjOF8wrYP
Mar 28, 2025 at 10:13 AM
CTISH84
  • 4 POSTS
Got the oil changed and when I first started it up there was no tapping noise but after it was running for, I'm going to say maybe 2 minutes it started tapping again.
Mar 31, 2025 at 2:32 PM
You probably have a worn timing chain or guide that has broken, that is what happened to the engine in the video.
Apr 1, 2025 at 8:59 AM
