tapping
2001 DODGE RAM
130,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
JWHITE2007
My truck makes a prett loud tapping noise. It only does it once it is warmed up. I've done a lot of research on it and it sounds just like a stuck lifter but it's louder than most videos I've seen. And most everywhere I've read on lifters says that the noise starts right when fired up and goes away when warmed up. But my truck does the opposite. It takes about ten minutes after I fire it up to start tappinng. And it does this untill the transmission hits the last two gears. Then the noise is very faint. Untill I let off the Gas then it's right back it.
Feb 6, 2016 at 8:51 AM
HMAC300
  • 48,601 POSTS
check to see if any torque converter bolts are loose, they may be hitting back of block
Feb 6, 2016 at 10:16 AM
JWHITE2007
Thanks for the response. I checked, nothing showed any signs of hitting anything
Feb 7, 2016 at 11:42 AM
HMAC300
  • 48,601 POSTS
you have to physically check to see if they are loose not if they are hitting anything. i have no further comments because i can't hear the noise.
Feb 7, 2016 at 12:11 PM
