Hi, I have this problem with my vehicle, when starting the vehicle it takes couples of seconds to turn on? Also when it's on it sounds smooth and good but then when I shift to drive it jerks pretty bad, and when I press on the gas the rpm's is going on 3,000 close to 4,000 and speedometer is barely going 10 mph why is that? It has to reach 3,500 to 4,000 to change gears what can it be? I changed the MAP sensor, crankshaft position sensor, changed 2 ignition could,did an oil change, and charged the battery.
Apr 15, 2020 at 11:56 AM
