Tail lights won’t work along with license plate lights.
2017 NISSAN VERSA
189,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
2017NISSANVERSA
Ok so after my license plate bulb blew as far as I know, my tail lights stopped working. Brake lights work fine along with turn signals. We checked bulbs and fuse. Both are fine. What else could cause this bc we are at a loss. Money is tight so doing a bunch of diagnostics is too expensive.
Nov 8, 2025 at 12:19 PM
I hear ya there, money is tight for most people right now, first I would confirm power at the fuse # 37 in the IPDM under the hood with the key on, this guide can help you
If you have power at the fuse, the tail light relay is integrated inside the IPDM (Intelligent Power Distribution Module), and it is not serviceable separately. Bummer, so you will need to replace the IPDM to fix the problem. There is a small chance the wiring to the junction block at the left hand of the dash is bad, (this is where the wiring branches out to the lighting system) but 9 times out of 10 it will be the IPDM. Please upload a short video in your response of the problem, so we can see what's going on.
Nov 9, 2025 at 11:33 AM
2017NISSANVERSA
We got it figured out! Thanks so much! It was that main fuse we just couldn’t get to it without removing some parts I think is what my boyfriend said. We REALLY appreciate your help!
Nov 9, 2025 at 5:44 PM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help :)
Can you please leave us a rating?
https://g.page/r/CZdEnyCkGgm6EB0/review
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you!
Nov 10, 2025 at 9:12 AM
