HEYMAN 1104, I want to start by saying thanks for the quick reply. but i think i need to be a little more specific. i put the aftermarket radio in about three weeks to a month ago, and everything has been working well up until about three days ago. i still want to go behind my radio and look around for maybe a loose wire, because i have no burnt fuses. and i did mention that i replaced 95% of my inside and outside bulbs with LED bulbs. but that was also at the same time i installed the radio. so i am wondering if i back tracked and replaced all the LED bulbs with the original bulbs, if that may help? i am trying to remember anything and everything i tried or heard to try. one more thing is i tried to replace my glove box light with just a regular bulb since i did not have an LED to replace that one with, and it did not work. when i first tried to change it, the bulb would light up and go out, light up and go out again. so i was wondering if that could be my problem area? i heard there is a relay under the dash that could be giving me this problem. because like i mentioned all my fuses are good not a single one is bad. anything anyone can do to help would help me tremendously. i am a single dad and i am not rich by any means. Thanks everyone in advance. Also, i replaced the dimmer switch with like four other ones i got from my local bone yard, so i know i cannot be that. Before i replaced it, i tried to see if there was power to the switch, and no there is not. i am stumped.
Mar 3, 2018 at 9:14 PM
