Tail lights and consoles lights do not work
2007 TOYOTA COROLLA
9,700,000 MILES • 1.4L • FWD • AUTOMATIC
DBGIRL
  • 9 POSTS
Please help. tail lights and console lights do not work. All other lights work. Fuses, bulbs and headlight switch checked. Car has a daytime running light system. Need to get tail lights to work. can you help?
Nov 6, 2016 at 7:20 AM
HMAC300
  • 48,601 POSTS
check the two relays in picture see if power goes in and out lights will need to be on to test.
Nov 6, 2016 at 8:26 AM
DBGIRL
  • 9 POSTS
Thank you.I think that was tested but I will check. If so what else can be checked?
Nov 6, 2016 at 2:10 PM
HMAC300
  • 48,601 POSTS
well it could be multi function switch or body module which would need to be scanned for codes by a mechanic.
Nov 6, 2016 at 3:42 PM
DBGIRL
  • 9 POSTS
The multi function switch (which is the light switch right?) has been checked.where is the body module located? Can that be done by any mechanic? Thanks for responding to my questions by the way. I do greatly appreciate it. I really need to get this fixed.
Nov 6, 2016 at 4:55 PM
DBGIRL
  • 9 POSTS
P.S, would the DRL module have anything to do with it?
Nov 6, 2016 at 5:09 PM
HMAC300
  • 48,601 POSTS
if DRL module were bad a mechanic with a scanner would pick that up anyhow. your body module is called an integration relay it's on instrument panel junction block so check for loose wires or bad connections.
Nov 7, 2016 at 6:23 AM
DBGIRL
  • 9 POSTS
Is disconnect of battery and reconnect recommended?
Nov 7, 2016 at 7:29 AM
HMAC300
  • 48,601 POSTS
you can try it, but I do not think it will work.
Nov 7, 2016 at 8:08 AM
DBGIRL
  • 9 POSTS
Thank you so very much..you have been great. Guess I have to try and find someone to check the things you have mentioned . Wish me luck.
Thanks again,
Dbgirl
Nov 7, 2016 at 8:13 AM
Please let us know what you find so it will help others.
Best, Ken
Nov 9, 2016 at 9:27 AM
DBGIRL
  • 9 POSTS
Ok
Nov 9, 2016 at 9:39 AM
DBGIRL
  • 9 POSTS
Hello ken,
Well HMac300 was correct in saying check the relays. The problem was the tail light relay which is very hard to get to. Top of dash had to be taken off and vent on passenger side. Apparently this is a common problem in the toyota corolla according to the mechanic but its fixed yay!
Thank you for your assist,
Dbgirl :-)
Nov 9, 2016 at 3:35 PM
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Nov 10, 2016 at 9:02 AM
DBGIRL
  • 9 POSTS
Thank you...
Nov 10, 2016 at 9:06 AM
