Tail lights do not work when I have my headlights on
2008 CHRYSLER PT CRUISER
167,786 MILES • 2.1L • 6 CYL • 2WD • AUTOMATIC
JANICE RATH
My brake lights work fine. Is there a fuse for my tail lights?
Jan 4, 2019 at 3:21 PM
There is a a fuse for these lamps but it is also for the license plate lamp so if that is out as well then the fuse is the issue. Here is a guide that will help with this:
Also, here is a guide that will help with testing the voltage as that is what we need to do in order to figure out what the issue is:
Below is the wiring diagrams from the manual that will help with this in order to figure out what the possible issue is. However, I suspect you will find the fuse is the issue if the plate light is out as well.
Please let us know if you have other questions. Thanks
Jun 10, 2021 at 3:28 PM
