tail lights
2005 HYUNDAI ELANTRA
101,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOMMYTUPPENCE74
When I shut my car off tonight the tail lights stayed on. The headlights are off, there are no warning lights or any other problem. I restarted and turned off the car and lights a few times, they are still on after four hours.
Feb 23, 2018 at 10:46 PM
MIKE H R
  • 3,094 POSTS
check the positioning switch, it keeps the tail lights on when the switch is turned on in case of a brake down on the road.
Feb 26, 2018 at 8:56 AM
TOMMYTUPPENCE74
I don't know what the positioning switch is or where it's located. I also don't understand what "a break down on the road" means.
Feb 27, 2018 at 10:01 AM
You have a tail light relay that is stuck on and needs to be replaced. Here is a wiring diagram for the running lights so you can see how the system works and a guide to help you test the relay once you find it from the diagrams below.
The relay is under the dash on the drivers side here are fuse and relay locations so you can see where to find it. I would save this page in your favorites for future reference.\
Feb 27, 2018 at 10:20 AM
