I need you to check a fuse and a relay. If you look below, I attached the wiring schematic for the vehicle's exterior lighting. These are for a sedan. If you have a hatchback, let me know because they are different.
There were two pages of schematics. I had to cut each in half to make them readable, but I did overlap them so you can follow from one to the next. I also highlighted the wiring to the lights from the fuse.
First, confirm fuse 37 in the under-hood fuse box is good. In addition to checking the fuse, confirm there is power to it. Note: Power to the fuse will only be present when the lights are turned on.
If the fuse is good and there is no power, we need to go back to the relay. If there is another one having the same part number, switch them to see if things change. If there isn't one, here is a link that shows how to test one.
If that doesn't help, we need to confirm there is power to it. Power comes from a fusible link (link D near battery box). I will need you to inspect that as well.
See pics below.
Pics 5 and 6 show fuse locations.
Dec 11, 2021 at 11:42 PM
