taillights flickering?
2004 PONTIAC VIBE
207,000 MILES • 4 CYL • 2WD • MANUAL
DANIEL HYATT
  • 4 POSTS
taillight flickering but all other lights work.
Apr 30, 2024 at 11:27 AM
This can be the headlight switch or the taillight relay, here is the location of the relay so you can swap it out which will be easy. Also, here is a guide to go over that can help as well:
https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Apr 30, 2024 at 11:36 AM
DANIEL HYATT
  • 4 POSTS
how do i change the relay? it's wires not a plug.
May 1, 2024 at 10:03 AM
Can you upload an images of what you are seeing? The relay should just pull out from the relay box.
May 2, 2024 at 8:50 AM
DANIEL HYATT
  • 4 POSTS
unsure i have the right location. what i found that looks like the images was behind the glove box under the dash.
May 2, 2024 at 8:55 AM
The relay should be on the backside of the fuse panel on the right side of the dash. Let me know, upload images please so I can confirm you have the correct relay.
May 2, 2024 at 12:57 PM
