I'm tracking down a trunk leak. I want to remove the center tail light to check and/or replace the gasket. Got the bulb bar out. It was held on with phillips screws. the mounting bracket for it which also holds on the tail light lens is held on by two (?) somethings. They're recessed and you can't really see them. I've tried several small Alen wrenches and screwdrivers. What kind of screws are those and how do you remover them?
Thanks,
Jim
Thanks,
Jim
May 29, 2013 at 12:12 PM
