Taillight and running light not working?
2018 CADILLAC ESCALADE ESV
59,620 MILES • 6.0L • V8 • 4WD • AUTOMATIC
The right taillight and running light not working, but brake like and blinker work.
Jul 7, 2023 at 7:39 PM
The first thing to check is the fuse for the right parking lamps. See pic 1. When you check the fuse, make sure there is power to and from it. Note: Power will only be present when the lights are turned on.
If that is good, then I need you to check for power at the light assembly. There is a green wire to the lamp assembly that powers the parking lamp. See if there is power to it. See pic 2 below.
Try these things and let me know what you find.
Note: If the front right parking lamps work, the fuse isn't the problem so move to the rear lamp wiring testing. Pic 3 shows the fuse location.
Jul 7, 2023 at 9:37 PM
Thank you. I will check this.
Jul 8, 2023 at 6:04 AM
You are very welcome. If you have a chance, let me know what you find. If that isn't the issue, we can move on.
Jul 8, 2023 at 8:34 PM
