Passenger side rear taillight does not work?
2000 AUDI A4
150,000 MILES • AUTOMATIC
DOLLABILL25
  • 44 POSTS
Okay, so my passenger rear taillight doesn't work brake light works. I get voltage to all my wires except for one wire. so, I was just curious what the wiring diagram/pin out is for my taillights, brake lights, blinkers, reverse lights, etc etc. thank you
Dec 12, 2023 at 6:10 PM
There is a rear lamp control module that may be faulty. What color is the wire that has no power? If it is brown, that is likely the ground, so no power would be there. Also, are you certain the bulb is good?
I attached a pic below of the optional schematics based on options. Take a look and let me know which you have and I'll get you the schematics.
See pic below.
Dec 12, 2023 at 7:20 PM
DOLLABILL25
  • 44 POSTS
The 2nd, 3rd, and 4th one please. thank you
Dec 13, 2023 at 1:06 AM
DOLLABILL25
  • 44 POSTS
Yes, brand new bulbs and it's not the ground wire it's a red with black stripe I believe.
Dec 13, 2023 at 1:07 AM
There is a red/black in the schematics. I followed it and it ran to the rear light control module.
There are three sets of schematics below. I had to cut them in half to make each one readable. The first two are number 2, the next two are number 3, and the last two are number 4 from the list you requested. I wrote numbers 2 and 3 in two of the pics which are numbers 3 and 4 from the ones requested.
Let me know if this helps.
See pics below.
Dec 13, 2023 at 7:00 PM
DOLLABILL25
  • 44 POSTS
Yes, it did, thank you very much.
Dec 14, 2023 at 7:54 AM
No problem. Let me know what you find or if I can help in any way.
Dec 14, 2023 at 8:09 PM
