Welcome to 2CarPros.
I feel you are on the right track with the sensor. Although a new sensor did worse, it may be bad. Here is what I need you to check.
You will need a live data scanner to do this. When the engine stalls and will not start, using the scanner, see if there is an RPM signal. If there is no signal, try a different sensor.
If you have no access to a scanner, when it won't start, you will need to check for spark to the plugs. Here is a link that explains how that is done:
Here is a link that explains common symptoms related to a failing crankshaft position sensor. See if it seems to mirror what you are experiencing.
Also, when it is running, does the check engine light stay on? If so, have you scanned for diagnostic trouble codes?
Oct 22, 2019 at 7:13 PM
