Tachometer speedometer and shift indicator not working
1995 CHEVROLET 1500
150,123 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SAMIAM0619
How can I test what kinda of numbers I am looking for when testing sensors and where can I find them? I ask this because I’ve seen here on the site and through the internet that I could be VSS, a-b solenoids in transmission pan or ignition switch. My problem comes and goes. I turn truck off sometimes disconnect battery reconnect start truck and it runs fine sometime over night.
Sep 26, 2019 at 3:51 PM
This sounds like the cluster is shorting out causing the issue. here is a video that shows how to fix it:
https://youtu.be/_HEC44xENxw
Sep 29, 2019 at 10:42 AM
