Tachometer and overdrive lights are blinking
1996 FORD MUSTANG
100,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
KEYSERSZ
Car has low torque when i first press the accelerator wont even pass a speed bump without a little head start and the tachometer is also not working. i did notice the other day that the overdrive light went off and the tachometer started working again and the torque came back. this went on for a few minutes soon after the overdrive light started flashing again and lost torque again.
May 1, 2020 at 8:28 AM
This sounds like a possible speed sensor issue or even a throttle position sensor but we need to start with codes because there are a lot of possible causes and we don't have enough to go on yet.
Here is a guide on how to check for codes or you can stop by a parts store that does this and they will get the codes free of charge:
Let me know what you find and we can go from there. Thanks
https://www.2carpros.com/articles/symptoms-of-low-engine-power
May 2, 2020 at 9:01 AM
KEYSERSZ
So I have checked the codes on the vehicle and they are as follows:
P0708
P1131
P0117
P0755
P1445
Also I have noticed the negative battery cable gets really hot in sure there is a ground issues also can that cause some of these codes?
May 2, 2020 at 2:00 PM
P0708 - Transmission Range sensor is open
P0755 - Shift Solenoid Electrical malfunction
P0117 - Sensor signal voltage is low
P1445 - Purge Flow sensor circuit issue
Based on these codes it appears you have a wiring issue with the transmission. I would start with running through these DTCs diag steps and see where it leads you then update me on what you find and we can go from there. Thanks
May 3, 2020 at 5:07 PM
KEYSERSZ
On the instructions it states if the tool fits to go to TD2 however there is no TD2 sheet.
May 3, 2020 at 9:08 PM
Sorry. Here are the couple of sheets needed. I thought I looked at that but clearly didn't provide it.
May 4, 2020 at 6:38 PM
