It is behind the instrument panel. I attached two pics.
Here are the directions for removal. Picture 3 correlates with these directions.
___________________
Removal
Lighting: turn signal flasher assembly: removal
1. Remove front door scuff plate left hand see: headliner > removal and replacement > removal
2. Remove cowl side trim sub-assembly left hand see: headliner > removal and replacement > removal
3. Remove lower instrument panel finish panel left hand (for TMC made) see: dashboard / instrument panel > removal and replacement > removal
4. Remove lower instrument panel finish panel left hand (for TMMK made) see: dashboard / instrument panel > removal and replacement > removal
5. Remove steering column cover (for TMC made) see: dashboard / instrument panel > removal and replacement > removal
6. Remove steering column cover (for TMMK made) see: dashboard / instrument panel > removal and replacement > removal
7. Remove no. 1 instrument panel sub-assembly (for TMC made) see: dashboard / instrument panel > removal and replacement > removal
8. Remove no. 1 instrument panel sub-assembly (for TMMK made) see: dashboard / instrument panel > removal and replacement > removal
9. Remove lower instrument panel finish panel (for TMC made) see: dashboard / instrument panel > removal and replacement > removal
10. Remove lower instrument panel finish panel (for TMMKmade) see: dashboard / instrument panel > removal and replacement > removal
11. Remove instrument cluster finish panel no.1 see: instrument cluster / carrier > removal and replacement > removal
12. Remove combination meter assembly see: instrument cluster / carrier > removal and replacement > removal
13. Remove turn signal flasher assembly
(a)Disconnect the connector.
See picture 3
(b)Remove the clamp and the turn signal flasher assembly.
Install:
Installation
Lighting: turn signal flasher assembly: installation
1. Install turn signal flasher assembly
(a)install the clamp and the turn signal flasher assembly.
See pic 3
(b)connect the connector.
2. Install combination meter assembly see: instrument cluster / carrier > removal and replacement > installation
3. Install instrument cluster finish panel no.1 see: instrument cluster / carrier > removal and replacement > installation
4. Install lower instrument panel finish panel (for TMC made) see: dashboard / instrument panel > removal and replacement > installation
5. Install lower instrument panel finish panel (for TMMKmade) see: dashboard / instrument panel > removal and replacement > installation
6. Install no. 1 instrument panel sub-assembly (for TMC made) see: dashboard / instrument panel > removal and replacement > installation
7. Install no. 1 instrument panel sub-assembly (for TMMK made) see: dashboard / instrument panel > removal and replacement > installation
8. Install steering column cover (for TMC made) see: dashboard / instrument panel > removal and replacement > installation
9. Install steering column cover (for TMMK made) see: dashboard / instrument panel > removal and replacement > installation
10. Install lower instrument panel finish panel left hand (for TMC made) see: dashboard / instrument panel > removal and replacement > installation
11. Install lower instrument panel finish panel left hand (for TMMK made) see: dashboard / instrument panel > removal and replacement > installation
12. Install cowl side trim sub-assembly left hand see: headliner > removal and replacement > installation
13. Install front door scuff plate left hand see: headliner > removal and replacement > installation
Let me know what you find,
Dec 26, 2018 at 6:22 PM
