My vehicle listed above, the airbag light is on, TCS is on. Sometimes it comes on and out. The car runs fine only a problem with the misfires and stalling sometimes at turning, low speed or first startup. When I turned off the ignition and restarted it, it acts fine. At high speed also it runs better. The misfires went out. I did replace these parts from junkyard-throttle body, MAF sensor, ignition coils etc. No difference. Finally replaced new spark its again works fine for a month. Now its again started the same issues but little worse. No idea what to do since 6 months' suffering with this same issues. Is this causing faulty fuel pump issues..?? . If its fuel pump it will happen every time I guess. But its only in sometimes means some other issues.
May 9, 2023 at 7:06 AM
