New cylinder in it is still hard to turn ignition key
1991 FORD RANGER
400,000 MILES • 2.9L • 6 CYL • 2WD
PERR1966
Key wont turn turn off. i put a new cylinder in it is still hard to turn, i can turn it with some pliers.
Mar 20, 2019 at 1:31 PM
JOETECHPRO
  • 705 POSTS
Hey PERR1966,
From what i can see the turning the key moves a push-rod which goes into the actual ignition switch. The ignition switch is fitted further down the steering column.
If the ignition switch is stiff or something is stopping the rod moving freely you will get the symptom you are experiencing.
You will need to remove the column cowl to inspect.
I would suspect you need a new ignition switch.
Regards, Joe
Mar 20, 2019 at 4:16 PM
PERR1966
Thanks, i will try it and let you know.
Mar 20, 2019 at 9:08 PM
JOETECHPRO
  • 705 POSTS
Hey PERR1966,
Perfect, let us know you you progress with the repair.
Regards, Joe
Mar 21, 2019 at 8:42 AM
