Sway bar replacement
2004 CHEVROLET TRACKER
100,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
MASTER B
I took off the old sway bar and had to cut off the links. Upon replacing it with new links my truck is leaning badly to the right side. The front-end is leaning. What do I need to do?
Aug 24, 2020 at 10:03 AM
STEVE W.
  • 15,113 POSTS
With that description I would measure both links to be sure they are the same length. If those were the only part changed then one longer than the other could do it. Unless something happened to move a spring or perhaps a broken one.
Aug 24, 2020 at 11:08 AM
