Replacing sway bar link on passenger side
2008 CHEVROLET COBALT
126,208 MILES • 2.2L • 4 CYL • 2WD • MANUAL
AZDANNO04
  • 343 POSTS
What are the torque specs for the sway bar link and if I have to remove anything else what else do I need to tighten up with the torque specs? I marked everything with white out if I keep everything close and the steering wheel straight. what else can help me from having to do an alignment?
Apr 14, 2022 at 12:28 PM
SQM
  • 6,383 POSTS
Replacing the sway bar links can be done by only removing the wheel/tire.
If you are just replacing the sway bar link, you do not have to do alignment.
I have attached the replacement procedure with the torque specifications below.
https://youtu.be/y5zN-7XTEto
Let me know of any questions.
Thank you.
Apr 14, 2022 at 2:26 PM
