i switched a 1996 403 transmission into a 1990. Worked before, now as a test, it lags. I converted the speedometer module, the other two module plugs fit. One is a three-pin round, the other a two-wire like-a-molex. Anybody know anything about this "delemon". Is it possible that three-pin is upside down?? Ironically one flywheel hole-to-converter did notT Line-up.. but 3-DID... That was very unique. YES, i did try spinning the converter in all 4 combination.. Can any one help this fool? (although, sometimes being a fool can be fun... lol.. CRZ)
1996 was 3500, regular length, the 1990 is extended 3500, same general casing, but the 1996 has that 2 wire sensor at cross member, the other was slightly different, but same fitting-plug. Also i have no clue what ST LB rwd means. Mine-both were RWD, only.
Jan 27, 2020 at 6:46 PM
