Problem starting
2007 SUZUKI XL7
24,000 MILES • 6 CYL • AWD • AUTOMATIC
NUNZIOPITIFER
Intermittant - sometimes when I turn key - nothing, no sound, no crank, no starter turn, nothing. Have to try several times before it 'engages' and turns starter.
At times when it does turn right over, it will turn over but won't start (like it's out of gas).
I've noticed battery will go from 14.4 to 13.3 to 12.2 over a few days (when I first turn on). Usually after driving for several minutes its back up to 14.1-14.4
Apr 8, 2010 at 11:44 PM
DAVE H
  • 13,384 POSTS
start by checking the wiring..
See the guide below about bad connections at the battery
Apr 30, 2010 at 4:48 AM
NUNZIOPITIFER
Electrical problem 6 cyl All Wheel Drive 24000 miles
When I turn the key - nothing, no cranking, no starter noise, nothing. Have to try several times before it will engage.
Othertimes it turns over and over and over and takes several trays before it will start (like it's out of gas)
Oct 10, 2018 at 4:51 PM (Merged)
It sounds like you have two problems her first is the starter motor sounds like it is going out. Here is a guide to help you see what you are in for when doing the job.
The next sounds like your throttle actuator needs to be serviced because when it is dirty the engine tends to stall and hard start.
NUNZIOPITIFER
Man I did what you said for both got the starter from Amazon and the car has never been better thanks for helping me :)
