2004 Suzuki XL7 Water Pump
2004 SUZUKI XL7
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
DLILLY
Radiator level is within working levels but temperature gauge rises and falls and there is no heat. Is this a potential water pump issue. My wife has taken car to a Midas car care center and they told her it was a water pump and the cost is 1300.00 Is this the average cost for a replacement?
Feb 20, 2010 at 9:24 PM
DAVE H
  • 13,384 POSTS
check/replace thermostat .. flush cooling system .. labor time on pump replace is 14 hours and $80 for pump
Mar 15, 2010 at 6:39 AM
DAVE H
  • 13,384 POSTS
WATER PUMP LEAK
TECHNICAL SERVICE BULLETIN
Reference Number(s): TS 06 03296, Date of Issue: March 29, 2006
SUZUKI:All
SECTION:Engine
Related Ref Number(s): TS 06 03296
ARTICLE BEGINNING
CONDITION
Signs of coolant leakage at water pump weep hole.
CAUSE
During break in, some coolant will pass through the seal and leave green and white deposits around and below the weep hole.
CORRECTION
If these deposits of coolant are found around the weep hole do not replace the water pump.
If these deposits of coolant are found and coolant is visibly leaking from the weep hole enough to drip on to the ground, replace the water pump.
Mar 15, 2010 at 6:44 AM
