I believe itis a 50 Torx, be careful not to strip it
GENERATOR
Removal
Disconnect negative cable at battery.
Disconnect generator lead wire ("B" terminal wire) and coupler from generator.
Remove generator belt. See GENERATOR BELT .
Remove generator drive belt adjusting bolt and generator mounting bolt.
Remove generator.
Installation
Mount generator on the generator bracket.
Tighten generator bolts (upper bolt "1", lower bolt "2") to specification. See TORQUE SPECIFICATIONS .
Install generator (cooling fan) belt. See GENERATOR BELT .
Connect "B" terminal wire "3" and coupler to generator. Tighten "B" terminal outer nut "b" to the specification. See Fig. 18 .
Install canister.
Connect negative cable at battery.
Apr 27, 2010 at 4:43 AM
