My wife drove home no problem. when i started it 2 hours later abs light and e brake light came on. then when i pushed the brake while in park, I can hear a click sound in the counsole box next to the gear shift. the brakes seemed a little squishy, and pulled a lttle bit to the left, but i am not sure since i don't drive it very often. i checked the fluid level and it looks good. a little below the full line, so i topped it off. did not make any difference. not sure if there is a leak in the system i will do a quick check, once my daughter takes a nap. this is the first real problem i have had with this rig. any info or help would be much appriciated. you guys really saved my butt on my 4runner fuel issue. keep up the good work.
Mario
Mario
Jan 21, 2009 at 2:19 PM
