2000 Suzuki Grand Vitara White smoke from tailpipe when i s
2000 SUZUKI VITARA
83,000 MILES • 6 CYL • 4WD • AUTOMATIC
SPARKLES169
  • 4 POSTS
HELP!!!!! Why is there smoke coming from the tail pipe when I start the car. What can I do to fix myself? I haven't had tune up in awhile, so hopeful this is a easy fix. When I recently had oil change done by the church the mechanic told me there was something loose in the front of my engine he thought it had to do with a bereing that turns the fan belt and run the alternater are the to problems connected. I am worried that if i don't get fix right a way its going to lead to other problems. HELP!
Jul 19, 2008 at 11:04 AM
DOCFIXIT
  • 18,828 POSTS
White smoke is indicating coolant in the combustion chamber. Check coolant level down? Presure test coolant system if it does not hold pull plugs crank coolant come out spak plug hole? Then blown gasket or cracked head.
Jul 19, 2008 at 11:21 AM
SPARKLES169
  • 4 POSTS
How would I go about doing pressue test myself. Can I?
Jul 19, 2008 at 11:35 AM
DOCFIXIT
  • 18,828 POSTS
Auto zone may rent the tester?
Is the smoke white ?
Jul 19, 2008 at 11:41 AM
SPARKLES169
  • 4 POSTS
Yes, the smoke is white and only happens when the I start the car. After I check the pressure what am looking for
Jul 19, 2008 at 11:45 AM
DOCFIXIT
  • 18,828 POSTS
pull plugs let sit pressurized for couple hours crank water out plug holes blown gasket. You will need to remove head have it plained and replace.
Jul 19, 2008 at 11:56 AM
SPARKLES169
  • 4 POSTS
That all sounds real expensive, I was hoping it would be an easy fix. Hopefully it doesn't lead to other problems. This is my only car and can't afford to take it in right now.
Jul 19, 2008 at 12:02 PM
DOCFIXIT
  • 18,828 POSTS
It will only get worse and could lead to bearing failure resulting in a rebuild. If you keep driving keep close eye on oil when it begins looking like a choclate malt STOP
Jul 19, 2008 at 12:06 PM
JENNIFER WALLACH
  • 4 POSTS
PVC Valve!
Nov 11, 2016 at 8:57 AM
JENNIFER WALLACH
  • 4 POSTS
Typo sorry! PCV valve I had the same problem. $6 fix!!
Nov 11, 2016 at 9:04 AM
