2000 Suzuki Grand Vitara p0305
2000 SUZUKI VITARA
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
FAIRLAWN07
I am getting p0305. The engine vibrate slightly at idle, once i touch the gas pedal it runs fine, Accelaration and high speed are fine. I replaced spark plugs, switched cylinder 5 and 3 ignition coil. I am still getting p0305.
Jan 20, 2008 at 6:10 PM
KYTERRYLEE
  • 8 POSTS
This can be a false code. There is a TSB on this code but you need to check with a Suzuki dealer to see if your vehicle has the TSB for this code. The TSB recommends replacing the ECM.
Mar 19, 2009 at 5:06 PM
