1999 Suzuki Grand Vitara changing brake rotors
1999 SUZUKI VITARA
ARCHERACE
Brakes problem
1999 Suzuki Grand Vitara 6 cyl Four Wheel Drive Automatic
After i have removed the caliper how do I get the front rotors off my grand vitara
Jul 16, 2008 at 4:47 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4e2fdc92b3="archerace"]Brakes problem
After i have removed the caliper how do I get the front rotors off my grand vitara[/quote:4e2fdc92b3]
Some vehicle have a 2 spring clips on the Studs. If not the most likely have rusted on so you will need to spray some lubricant on the rotor around the studs and center whole let set for 15 - 20 minutes o soak in then take hammer and hit inbetween the studs may take a few good hits then tap down on the top of rotor. it should break loose.
Jul 16, 2008 at 5:43 PM
