2004 Suzuki Verona Engine code P1382
2004 SUZUKI VERONA
82,000 MILES • 6 CYL • FWD • AUTOMATIC
CDSTROUD
I have gone to mechanics and get a different answer as to what this code is p1382.
I looked online and found that suzuki was listed on this code as ABS wheel speed sensor. This kind of makes sense since the abs light is on. The car runs fine and brakes fine. I cannot get it inspected until the check engine light is off.
What to do nobody seems to know.
Nov 5, 2008 at 12:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
What do you mean you can't get it inspected until the check engine light is off? You can go to your local Advance Auto Parts, O'Reilly Auto Parts, and many other auto parts stores and have the check engine code erased. If it is throwing the code you say then you should just simply replace the sensor and both the ABS and the Check Engine lights will go out..
Nov 5, 2008 at 12:26 AM
CDSTROUD
IF it was that simple I would have been finished except the sensors are fine and code has been erased and the light comes back on immediately. In this state upon inspection the computer is connected directly to the state central computer and it tracks erasures as well which are stored and requires a 30 mile no light record after erased to pass inspection.
If anyone has suzuki experience of this type please let me know. This is not a usual situation.
Nov 5, 2008 at 5:41 AM
LABMAN5
[quote:6760572754="cdstroud"]IF it was that simple I would have been finished except the sensors are fine and code has been erased and the light comes back on immediately. In this state upon inspection the computer is connected directly to the state central computer and it tracks erasures as well which are stored and requires a 30 mile no light record after erased to pass inspection.
If anyone has suzuki experience of this type please let me know. This is not a usual situation.[/quote:6760572754]
I have the exact problem ,I have 118,000 mi. same make and model
Nov 21, 2008 at 10:13 PM
LABMAN5
I have the same exact problem,118000 mi.
Nov 21, 2008 at 10:14 PM
CATEYES76542
I have been in and out of the shop with the same problem. Did you find out what is wrong with it. No one seems to have any ideal.
Jul 22, 2009 at 9:54 AM
LABMAN5
It turned out to be the front wheel bearing just starting to go bad, which I guess would change the speed of the wheel , thus give the speed sensor the error, so the sensor was ok, I replaced the wheel bearing which started to hum, after that ,the error went away. So if the wheel is humming slightly, it maybe going bad and give an error to the sensor.
Jul 23, 2009 at 1:13 PM
