IGNITION TIMING CONTROL SYSTEM
Advance Control
Ignition timing is controlled by ECM based upon sensor input signals. ECM controls ignition timing to a precise point by matching vehicles operating conditions to preprogrammed timing advance specifications stored in ECM memory. Signals generated by crank angle sensor are transmitted to ECM. These signals are modified by input signals from coolant (water) temperature sensor, airflow meter, throttle position sensor, idle switch, vehicle speed sensor and monitored battery voltage.
May 30, 2010 at 5:49 AM
