1992 Suzuki Swift engine timing
1992 SUZUKI SWIFT
13,000 MILES • 4 CYL • FWD • MANUAL
JAMES114
my car keeps going out of time,please tell me everything i need to check! I have replaced the timing belt and tensioner.
Jul 15, 2009 at 11:58 PM
DAVE H
  • 13,384 POSTS
IGNITION TIMING CONTROL SYSTEM
Advance Control
Ignition timing is controlled by ECM based upon sensor input signals. ECM controls ignition timing to a precise point by matching vehicles operating conditions to preprogrammed timing advance specifications stored in ECM memory. Signals generated by crank angle sensor are transmitted to ECM. These signals are modified by input signals from coolant (water) temperature sensor, airflow meter, throttle position sensor, idle switch, vehicle speed sensor and monitored battery voltage.
May 30, 2010 at 5:49 AM
