1992 Suzuki Swift crank angle sensor
1992 SUZUKI SWIFT
260,000 MILES • 4 CYL • 2WD • MANUAL
BYSHOPFOXX
This car used to jump around like a jack rabbit during acceleration but only after extreme cold weather. Now the vehicle wont start. at first the OBD was throwing code map sensor. Then the code changed to crank angle sensor. Now the car wont start but I can still hear a whirrring noise when i try to turn it over. This is the rare 1.6 suzuki swift SOHC that is also in the x90. I need some help finding the crank angle sensor as I think this is the problem. Do either of you guys know where the crank angle sensor is on this engine? I have already changed the Map sensor with several from the wreck yard and they never fixed the jumping car syndrome. thank you in advance for any advice you might have.
Mar 28, 2009 at 8:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Crank angle sensor is located inside the distributor..
Thanks for using 2CarPros.com!
Mar 30, 2009 at 12:05 AM
