1990 Suzuki Sidekick Wont Start
1990 SUZUKI SIDEKICK
266,500 MILES • 4 CYL • 4WD • MANUAL
GEORGIABOY1960
car was running, but my son always jump his car off by mine. lately he started up my car and it shut off and would not start back up. It has gas to the TBI and fire to the spark plugs. I unhooked the TBI and used a multimeter to check the power comming to the TBI. Its was showing .02ohms to .05ohms. When trying to start the car it was showing .022ohms. I did buy a new fuel injector but still wont start. The injector will not spray at all. I pulled out the computer out and did not see or smell any burn in it. What could be the problem. Thank you.
Jan 30, 2010 at 7:28 PM
Hi georgiaboy1960, Welcome to 2carpros and TY for the donation
Check for power at the red wire on the injector harness or use a noid lite if okay and its not synchronizing check the injector solenoid if okay the injector ground driver circuit is defective.
At the computer wiring connector B check for power at B1 and B7 no power here test the control relay
Jan 30, 2010 at 9:46 PM
