Hi, My car has developed a peculiar problem, when I turn on my parking and or headlights, my engine's RPMs increase to about 3,500 and stay there until I turn off the lights. This occurs regardless of engine speed/gear, driving or if I am at a stand still. All the fuses are good and I don't see an obvious short anywhere in the wires. I live in the Caribbean and no one around here seems to be able to diagnose this. To make matters worse, I think the increased RPMs are contributing to an overheating problem and have led to a water pump gasket leak. What do you think about the light/throttle issue? Also, can I get away with replacing the water pump gasket since a new pump is about 150 dollars here? Thank you in advance
Apr 10, 2009 at 5:52 PM
