IN THE LAST MONTH THE ENGINE HAS STALLED OUT 9 TIMES WHILE DRIVING. 5 TIMES AFTER GOING OVER RAILROAD TRACKS AT ABOUT 35 MPH, 1 TIME AFTER HITTING POT HOLE IN PARKING LOT AT ABOUT 3 MPH, 2 TIMES AFTER GOING OVER SHALLOW DIP IN THE ROAD AT ABOUT 40 MPH, (COMPLETELY LOST POWER WITHIN 5 SECONDS IN ALL OF THESE INSTANCES), AND 1 TIME WHILE DRIVING ON A SMOOTH ROAD AT ABOUT 60 MPH. AFTER SEVERAL MINUTES OF CRANKING, AND SOME TIMES NEEDING A JUMP DURING THE CRANKING IT WILL FINALLY START. AT FIRST I THOUGHT IT MAY HAVE BEEN FUEL RELATED (CHOKE STICKING). I DRAINED THE GAS TANK AND FOUND VERY LITTLE DIRT, AND THE FUEL FILTER WAS CLEAN. I RAN A CAN OF FUEL ADDITIVE THROUGH THE GAS TANK AND SPRAYED THE CARBURETOR WITH CLEANER. I DID HAVE ONE LEAKING VACUUM LINE WHICH I REPLACED. THE REASON I THOUGHT IT MIGHT BE ELECTRICAL INSTEAD OF FUEL RELATED IS BECAUSE OF THE SHORT TIME IT TAKES FOR THE ENGINE TO LOSE POWER AFTER GOING OVER THE TRACKS AND THE OTHER INSTANCES..
Sep 16, 2010 at 8:35 AM
