Engine Performance problem
1987 Suzuki Samurai 4 cyl Four Wheel Drive Manual 135K miles
87 Suzuki Samurai failed CA smog test with a fresh head, plugs, cap, rotor and timmed to perfection. HydroCarbon count was 54 points over the allowable limit (rich mixture/un-burnt fuel) everthing else passed . . . The Hitachi Carb is preset at the factory, one must remove the carb and remove a set pin in order to make any adjustments to the mixture.
The question: If I install a "hotter" spark plug, will this aid in burning the excess fuel and reduce the HC level seen at the smog station and thus "possibly" passing?
Thanks,
- - - Dave
Thanks,
- - - Dave
Jun 26, 2009 at 7:44 PM
