Vitara Turbo Diesel goes into limp mode
SUZUKI
SAFARIMAN
Just bought a Vitara TD with HDI engine on a 52 plate for my daughter to use but it problem is that the engine management light comes on and then the vehicle goes into limp mode if the vehicle is switch off then restarted its fine until the next time which there is no pattern and can be any when. We have ran a diagnostic check and the code reads 0230 primary fuel pump circuit malfunction, need to know if this is relay related or controlled any help or ideas much appreciated.... Many thanks Mike
Aug 7, 2007 at 10:04 AM
DAVE H
  • 13,384 POSTS
check/replace fuel pressure regulator
Jun 22, 2010 at 2:18 AM
