sputtering 96 sidekick, what could be the problem
1996 SUZUKI
BILLCHENEY46
I have a 16 valve 4 cyl 96 suzuki sidekick, I think i got bad gas. Changed F-filter, added injector cleaner/and octane booster. what do i check next? money is short so the cheapest solution first! please! :?
Apr 15, 2007 at 11:36 AM
ELECTRAGLIDE67
My sidekick in a 94 so not sure if all this will apply. Mine had a small crack in the distibutor cap which cause some problems. I swear by Lucas products and would reccomend there fuel treatment for you. Plugs, wires and new distributor cap (if you have a distributor) would be a good idea to check or replace. I also had a spark plug back out and come loose, that made it run like &*^% until tightened up. A stuck EGR valve will mess up your idle, or make engine stall at idle.
You werent real clear on when your sidekick is sputtering. Is it just at idle or is it running like crap while accelerating?
May 27, 2007 at 10:37 PM
