I have a 94 suzuki sidekick jx w/ 1.6 liter, 16 valve, MFI engine. It is 4-door, 4WD and has 125,000 miles on it. Recently it has started idling rough and has lost considerable power although it does still run. I have reset the timing properly and checked for any leaks, none, all the fluids seem fine.I replaced the plugs and ignition wires,the fuel is fresh,distributor cap and rotor seem o.k. I'm thinking it might be some sort of choke or vacuum problem because of the way it sounds and idles and also while it was idling I pulled off there is like an air resevoir type bottle that is on the air inflow line between the air filter and the injectors and that shut the engine down immediately. I would really appreciate some help. I enjoy this car.
Thank You,
gabzy
Thank You,
gabzy
Apr 21, 2007 at 9:38 PM
