Engine Mechanical problem
1999 Other Suzuki Models 4 cyl Two Wheel Drive Automatic
99 Suzuki swift 1.3 sohc 16 valves--
Am grinding valves. Rebuilt spring compressor to remove valves (with difficulty). Removed cam, but not rockers and shaft. Valves ground ok! ----
Question: any special sequence to reinstall valves and springs. -- Exhaust or intake first, Etc.?? --Note: Did remove removable rockers. ----- Before I start again, any advice? --- don't want to remove rocker shaft.
Thank you.
Thank you.
Nov 7, 2008 at 7:03 PM
