1999 Other Suzuki Models Loosing Engine Coolant / No Thermos
1999 SUZUKI
208,000 MILES • 4 CYL • 2WD • MANUAL
KHAHSAN
i removed my thermostat valve a month ago, now i am facing a problem that the coolant is finished every morning i start the car. there is no leak any where. I opened the radiator and got it checked as well all pipes every thing, there is no leak. now my car is getting hot every time i drive because of no coolant. coolant level drops even if i drive for as long as 20 km. there are no bubbles in the radiator opening so the gasket is fine and i got it replaced last week
please help
Sep 5, 2008 at 12:05 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The coolant has to be leaking internally or externally... so get a cooling system pressure test done first as this will locate any small external coolant leak.
mark (mhpautos)
Sep 5, 2008 at 12:56 AM
KHAHSAN
thank you mark, but in pakistan we dont have such facilities as a coolant system pressure check. and if there is any it will be hard to find. can u please advise an alternate
thanks
Sep 5, 2008 at 1:13 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
there is no other alternative, you can just let the car get up to full temp and allow the natural pressure to build, that is the only other way to check, you will have to look very carefully at all hoses seals and gaskets, don't forget the welsh plugs as well.
Mark (mhpautos)
Sep 5, 2008 at 1:25 AM
