1997 Other Suzuki Models Surging idle
1997 SUZUKI
PHILD131
Engine Performance problem
1997 Other Suzuki Models 4 cyl Four Wheel Drive Automatic
Sidekick idles very rough and dies when left in gear while stopped in traffic. Surging present when in park/neutral but engine is not as prone to stall. Stalling is worse if engine is under load at idle; using the air-conditioner.
Jul 24, 2008 at 2:03 PM
Check for vacuum leaks, test the idle speed controller, throttle positon sensor and also check fuel pressure.
Jul 24, 2008 at 2:12 PM
MOTORMAN900
  • 12 POSTS
Could be the throttle position sensor. In front of the throttle body it has two small screws which when loosened, allows the TPS to move around. You can play with the idle to your liking. Hope it helps.
Jul 10, 2009 at 9:40 AM
