1997 Other Suzuki Models Car runs cold
1997 SUZUKI
130,000 MILES • 4 CYL • 4WD • AUTOMATIC
RANDEYE
  • 6 POSTS
In cold weather I let the car reach normal operating temp. siiting in driveway. I then get on the highway and the temp. gauge drops all the way down below the cold mark. If I get off the highway and come to a stop, the temp slowly reaches normal again. I've replaced the thermostat 3 times with no luck solving the matter. Any ideas?
Feb 12, 2008 at 6:16 PM
DAVE H
  • 13,384 POSTS
check or replace the engine coolant tempreature sender !!
Apr 8, 2009 at 10:08 AM
KICK-FIX
  • 29 POSTS
what is wrong is everyone puts in the wrong stat.
I will assume the heater stay cold , you didnt say and that is the crucial issue.
if heater is ok , the temp sender is bad if not.
this.
on this generation there are 2 types.
paper gasket stat and special rubber ring stat.
yours (ours , i have 96) is the rubber ring and must not have a paper gasket.
see s.n.a.f.u. topic.
Sep 2, 2009 at 5:55 PM
