1995 Other Suzuki Models 1.3 Swift Automatic Not Starting
1995 SUZUKI
123,000 MILES • 4 CYL • FWD • AUTOMATIC
COOOL8BALL
Hi All, My Suzuki Swift, 4 cyl. ,1.3 Automatic, is not starting. 1st time, I jumped it & started, next time it wouldn't start I cleaned the batt. terminals (which were fairly clean) & replaced the terminal clamps, It then started 1st try so I let it run about 15 mins., 30 mins later, I started it again with no prob & also let it run a few mins to ensure a charge. tried again 2 hrs later with no problem. (By the way, I never moved the car from park during all of this) Next morning, it would not start-Dash lights up and all but has No indication of even trying to start. It does not make any starter noise, clicking(like low batt) or anything at all. I find it odd that it started 3 times in a row and I never even moved the car but would not start the 4th time--Thanks for your time to point me in the right direction
May 4, 2008 at 2:36 AM
LEGITIMATE007
  • 5,121 POSTS
you must check all connections, including to the starter, wiring could have corrosion inside the wire so be diligent when looking
May 4, 2008 at 4:35 AM
