1994 Other Suzuki Models Gas dripping from exhaust joints
1994 SUZUKI
200,000 MILES • 4 CYL • 4WD • MANUAL
JOE GRESHAM
H1!- 94 Suzuki Sidekick 1.6L 16v 4cyl. I noticed liquid dripping from joints of the exhaust system as well as leaking exhaust pressure. I replaced the flange gaskets and there is no longer pressure leaks at the joints, but there is still gas dripping...and pipe between cat and manifold appears to have a leak (it is covered with a shroud so I can't readily see). Trouble codes have ALWAYS read #51 (EGR), but I have cleaned and it has been doing fine till now. Also noticed much white smoke out the tail when driving. I suspect head gasket?.....but other input would be great!! Thank you!! - Joe
Jan 12, 2008 at 2:30 PM
DAVE H
  • 13,384 POSTS
check cylinder compression is good
Apr 25, 2010 at 2:52 AM
