1993 Other Suzuki Models Stalling
1993 SUZUKI
120,000 MILES • 4 CYL • 4WD • AUTOMATIC
Engine runs great untill it warms up. Then it idles rough and or dies. Seems like a relay or two clicks under the dash just before this occurs. also the check engine light comes on. cant get a dtc though overdrive wont engage either
Jan 13, 2008 at 7:19 PM
DAVE H
  • 13,384 POSTS
you will need suzuki to run a diagnostic scan on the vehicle to get the fault codes ?
Apr 8, 2009 at 9:36 AM
KICK-FIX
  • 29 POSTS
what car?
if your car is a sidekick you can pull the codes with no dealer at all, all 95 and older KICKS are that way.
as are most Suzuki's in this ERA.
see my sig link , cliick that and see my web page
and CHECK ENGINE LAMP.
92 's are natorius for the bad ECU.
and shorted fuel pumps.
but first pull the code by jumper the DLC and
reading out the blink codes on the CEL lamp.
only tool is a paper clip.
good luck to you.
Sep 2, 2009 at 6:23 PM
