1993 Other Suzuki Models acts like it is miss firing
1993 SUZUKI
117,000 MILES • 4 CYL • FWD • MANUAL
KENNGROS
  • 4 POSTS
I have a 93 suzuki swift 1.3liter sohc. it starts fine and idles fine, but when driving it acts like it is missfiring. i have replaced the plugs, plug wires, distributer cap, and rotor and oxygen sensor. after I replaced the cap and rotor it ran fine. then the next day it started doing it again, just not as often. I even removed the damaged catalaic convertor. Any ideas were to go next. could it be a timing belt, or bad distributor?
Feb 14, 2008 at 12:26 PM
RANDEYE
  • 6 POSTS
What brand of plugs did you use?
Feb 17, 2008 at 3:46 PM
KENNGROS
  • 4 POSTS
Bosch double platnums
Feb 18, 2008 at 11:21 AM
RANDEYE
  • 6 POSTS
I had a similar problem with my 97 Sidekick 4cyl 1.8. I tried 2 different plugs until I noticed in my manual it said to use NGK brand plugs. Since I put those in I haven't had the problem. I don't know if it will fix your problem, but it might be worth a try.
Feb 19, 2008 at 10:37 AM
KENNGROS
  • 4 POSTS
I'll try that. were did you find them? I'm not familiar with that brand.
Feb 22, 2008 at 5:14 PM
RANDEYE
  • 6 POSTS
I think they are available at most auto part stores. I got mine at Advanced Auto Parts / Parts America. I know O'Reilly carries them also. Let us know how it goes.
Feb 25, 2008 at 7:01 PM
NOT A PRO
I also had the same type of problem with my Suzuki
Forsa Turbo , but only when it got hot.
If your Swift still acts this way with new NGK plugs in it, you may have an intermittant injector if it is fuel injected.
Apr 16, 2008 at 11:33 PM
