2006 Suzuki Forenza stales, spits and hesitates at a steady
2006 SUZUKI FORENZA
48,945 MILES • 4 CYL • FWD • AUTOMATIC
FANIMODUAN
on start up it idles rough 1rpm the jumps to 1.5 rpm then i allow it to warm up and drive it had no drive i idled back to gagage and shut it down started and it was ok but still hesitation while driving 65 mph.. is it fuel filter, jets, or need a car major repair
Jul 11, 2010 at 12:49 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Jul 11, 2010 at 3:22 PM
