Inside Door Handle Removal and Installation
Removal
Remove the door seal trim. Refer to DOOR SEAL TRIM REMOVAL AND INSTALLATION .
Remove the tweeter speaker (if it is equipped) and the screw.
Slide the door handle forward and remove it from the door.
Disconnect the inside door handle and the lock rods.
Installation
Connect the inside door handle and the lock rods.
Insert the inside door handle into the slots in the door.
Slide the door handle rearward.
Install the inside door handle screw.
Install the door seal trim.
Mar 15, 2010 at 6:35 AM
